Flip phone
Merle2
Will a 3g phone fromAmazon work on this network
hairbag1
More info please...which phone are you considering ?
dust2dust
Likely. What exact make and model is it?
RossN
@Merle2 It is possible what is the make and model of the phone
hairbag1
The world, she is a changing. If you're considering buying a new phone...why not plan for future ? Sounds like 3g is going to be retired eventually, so get something that will be compatible with 4 or 5. Maybe even get something that will have WIFI calling compliant.
MrSpock
@Merle2 hello type your make and model into this website https://willmyphonework.net/
darlicious
@Merle2
If it's a flip phone you desire there are plenty of them available that also support 4G LTE. Given there durability if you choose one that only has 2G and 3G you are eliminating the lifespan of the phone to 3 years as the 3G network is scheduled to be decommissioned in Canada by the end of 2025 and there are already issues creeping up with voice calls in certain areas because pm currently uses 3G for voice.
