Fed up!
09-21-2022 08:05 PM
Locked out after entering correct password. Reset password....still can't get in.
I hate that there is no chat available. I need to buy a travel plan now.
Service
09-22-2022 06:47 AM
Good luck!
09-21-2022 08:14 PM
hi if you are having that many issues you need to contact a customer service agent they will help reset account
1. you can open a ticket through Simon here https://publicmobile.ca/chatbot.
2. alternatively you can private message them here
09-21-2022 08:14 PM
That's all kinds of trouble. Another access method is the chatbot. Start it and then say you're a customer and then sign in and then manage your account. See if your credentials work there.
09-21-2022 08:13 PM
Thank you. I'll try that tomorrow if I still can't get in.
09-21-2022 08:13 PM
Some Roaming Addons you are looking for may be available to purchase through calling 611 on your device @Ac56 . But it is really best to do this through My Account, is my thoughts.
If having issues with your password, use the Forgot your password option to reset it, found here: https://myaccount.publicmobile.ca/en/forgot-password
For My Account log in issues, you can submit a ticket here to: Create, forgot or change My Account email or password link
09-21-2022 08:12 PM
@Ac56 hi you can dial*611 follow the prompts you can purchase one that way also
09-21-2022 08:10 PM
I have three accounts. I'm locked out of all of them.
09-21-2022 08:09 PM
Yes. We're traveling to US tomorrow
09-21-2022 08:07 PM
trying different browser,open incognito mode,clear cache,cookie,
no travel plan, but you can buying add-ons for US only.
09-21-2022 08:06 PM
Try a different browser or device or use private mode. What do you mean travel plan? Do you mean one of the roaming add-ons offered here?
![](/skins/images/813D49D689E0D681E39391EAB60FD666/responsive_peak/images/icon_anonymous_message.png)
