04-03-2026
08:15 PM
04-03-2026
10:06 PM
computergeek541
Payed, downloaded app, ran activation to port my number. Failed, so contact support. Attempt to contact support failed. Not off to a good start here,.
04-03-2026 08:25 PM
I did, I could try again I suppose.
04-03-2026 08:20 PM
hi @Terry12345
For your activation problem, did you try reboot the phone then use PM app again and maybe it can complete the activation that way
if same, you will have to ask PM agent to help. You can submit ticket by direct message:
