Eversafe login problems
03-12-2024 03:15 PM
Logging into my account says I need to confirm my full access. Says it will send a 6 digit code associated with my eversafe ID to my ohone number, however it is sending to an incorrect phone number. I have no idea whose number it is being sent to. I'm unable to proceed any further. I'm not able to login to change the ohone number.
My Account
03-12-2024 03:25 PM
There is no other option other then resend code which it resend to wrong ohone number again. No option to select choose email
03-12-2024 03:22 PM
you can ask the code to send to email instead
On the screen it is expecting you to enter the code, click Didn't get the code? or Resend code and then choose Send email
if there is no such option
Please open ticket with PM support:
Start by typing "Submit a ticket", then click "Contact Us", then "Other", then "Log In", finally click "Click here to submit a ticket ↗"
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
03-12-2024 03:19 PM
hi @Gills93 try to get it via email. Click Didn't receive code and check if email is an option
if you cannot login still, support agent can help
please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
03-12-2024 03:19 PM - edited 03-12-2024 03:20 PM
I recommend that you open a ticket using the Chatbot at the bottom right corner
Firstly, type Contact,
then select the only choice: "Contact..",
then from the list, choose "Other"
finally click link the blue link to submit a ticket
Another page will open and follow the steps
After ticket is submitted, make sure to check your Community Inbox (the top right corner envelope icon) periodically for response from PM
![](/skins/images/97D9FB88C915001D8DAED89DBB2650DF/responsive_peak/images/icon_anonymous_message.png)
