Eversafe Opt out option?
Frustrated1111
As the title says, is there an option to opt out of Eversafe? I just deleted a bit of a rant. Suffice it to say, I'd really rather not use it. Not looking for help... just is it possible to opt out.
@Frustrated1111   Yes, it's not just login but they moved things around.  The main reason to use the EverSafe ID is that it allows a single login for both Community and My Account
Frustrated1111
Just simply frustrated with the number of changes to the system over the years, having to renavigate everything over and over. And for what I have no idea. The PM site is easily one of the worst I deal with for load times and simple access. Honestly, I have little interest in making it work. I'll figure out what I need to for now. Thanks.
@Frustrated1111   EverSafe is the name of the login system PM uses, not something you can opt out.  The old style login is no longer working
What issues you are facing?  Maybe we can help? share your questions
