Esim
jordan39
need esim
1 REPLY 1
@jordan39
New or existing subscriber?
if you are a new subscriber, simply download PM app, setup a new account and the step 2 will ask you if you want physical sim or esim
if you are existing subscriber, download the app on the phone where you want to install the eSIM and login the app.   If you have problem with receiving 2FA code, click "Didn't Receive code" or "Resend code" and choose either Send email or Send voice message
Once logged in, Click Account from the bottom, then click Purchase SIM Card and select eSIM.
Once it confirms your phone is eSIM compatible, click Pay $  and Install
