Esim
car62
Does anyone know how I can transfer my physical SIM card from my iPhone SE 2020 to my my new iPhone 14 I tried watching it on you tube but my mind can’t catch what they are saying
9 REPLIES 9
Leamon
In order to make the change, download and install the Public Mobile app on the new phone and buy a new eSIM card to replace the current one.
@car62  We happy to hear it enjoy the new iPhone 🙂
car62
  • You just made my life a lot easier I took the phone case off it there is I guess when you get older you get frustrated faster again thank you
I know @Handy1  - updated post to reflect this in case OP using a US based model.
Good catch 😉
@HALIMACS  And @car62 the iPhone 14 and even 15 are both physical sim and eSIM capable . Only if the device was bought in the U.S. would it only be eSIM iPhone
hi @car62 make sure to know esim cannot be transferred between phones.  So, you have to pay for new esim again when you change phone
To change physical to esim, download PM app.  Login the app, Subscription & Addon and then Shop esim to buy and install esim
Gwanzi
it is very easy, download Public mobile app in your new phone, and buy a esim from your app, then it will guide you to transfer! at the same time, do not put your old sim card in your phone!
HALIMACS
You simply remove the SIM card from the one device, and place it in the other.
CORRECTION:  the iPhone 14 is e-SIM only IF you got a US model...  you'll need to purchase an e-SIM from Public Mobile to use it in this new device.
Do so under the SHOP tab above.
@car62  Personally I just would just put the physical sim into the new iPhone 14 but if you really want eSIM you have to download the PM app on the new iphone14 and go to subscriptions add on page  . Notice shop sim now select it and choose sim download and install it that’s it
