Esim won't install on iPhone 11
07-24-2023 08:40 AM
07-25-2023 02:48 PM
@Eraf wrote:Installing app didn't trigger esim install. Scanning QR code triggers error. It is an iPhone 11
@Eraf since the QR code was not installed yet, pretty sure support can regenerate you a new one
Message support and make sure they are aware you the error when you try to install the QR code. You can message them here:
07-25-2023 02:44 PM
07-25-2023 02:44 PM
Yes, working with them!
07-25-2023 02:29 PM - edited 07-25-2023 02:47 PM
at which point you got the problem?
what phone you are using? brand and model?
you tried scanning the QR code you got from PM's email?
07-25-2023 02:09 PM
@Eraf Have you reached out to support to help
private message To CS_Agents click
VVVVV Link below VVVVV
07-25-2023 02:07 PM
Not yet!
07-24-2023 09:16 PM
Hi Eraf,
I am having the same issue. Were you able to fix it?
07-24-2023 08:54 AM
not sure if you tried that yet
there is a QR code in your Welcome email. Open it from a computer, or another device, then use your phone to scan it to install the eSIM profile on your phone
Once you installed the eSIM profile, (or If you got passed that step), try to reboot your phone once.
If it still does not connect and if you have any active sim on the phone , disable them (eSIM/Physica sim) or remove the physical sim. Then click Reset All Networks on your phone and it will work. (Please note that Reset all Networks will also erase your saved Wifi and Bluetoosh connections, but you just need to add them back after)
if it still does not work, please open ticket with PM support
07-24-2023 08:51 AM
@Eraf You can submit ticket with support
message support directly
while your already here and logged in the community you can send a private message To CS_Agents click
