a month ago
a month ago - last edited a month ago
@Patogo325 once you have physical sim card in hand can get from Telus /koodo store or order from Amazon $4.99 there . Then log into your account profile page and sim swap the number like this .
SIM SWAPPING profile tabs
You can do this in the app also “change SIM card “
If you can’t log into your account /app ask support to do it for you @Patogo325
⬇️⬇️⬇️⬇️⬇️Link below ⬇️⬇️⬇️⬇️⬇️
