Error shooting
Alex128
Does anyone know what to do with this? I am trying to get new subscription. I asked agent and she said delete the app, restart the phone and then try again, on web close everything restart the computer and try again and wait a minimum one hour with every attempt. I tried it several times last 8 hours but it still doesn’t work. When I said it’s still shooting the same problem it takes a while for agent to reply so I am trying it here.
7 REPLIES 7
@Alex128
@Alex128 wrote:
I tried that as well, but it did not work. This is the number of the error? Error Code: M.8702
I am getting one respond in 24 hours from the agents so its really hard to get any help and  fix it 😞
Unfortunately, the response times are slower over the weekend (likely due to staffing issues).
You have already tried most of the troubleshooting advice given by forum members.
Alex128
@Alex128
Were you charged for the activation?  Check your credit card online statement. If charged, you will need to follow up with customer service agent. Responses seem slower during weekends.
The website can be finicky.  Clear cache first, incognito  mode or a different web browser. Or try on a different device.
Alex128
Tried with another email and the same thing is happening
@Alex128 if you don't mind, use another email address to create the account.
But if you want to use the same email, ask PM to check to fix it
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:       https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
CS_Agent will reply to your community inbox between 9AM-10PM EST (Mon-Sun), check here:    https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
Alex128
Yes, I had an account before but it got cancelled and now I am trying to get a new one with new eSIM. I tried it on app and on website as well and both showing the error
@Alex128
Are you creating a new account and activating the SIM/eSIM on the PM app?
It can’t be done on the computer.
