05-08-2017 08:41 PM - edited 01-05-2022 02:03 AM
Hello everybody,
I just bought a new 20CAD prepaid card (from Metro store). I still have 10CAD left on my account from my previous 40CAD prepaid card (from Shoppers).
When I'm trying to add the new 20CAD voucher I get the message: "Unfortunately, Voucher #************ could not be added. Please verify the Voucher and try again."
I tried the "PIN#", I also tried the "Voucher #", both are 12 digits numbers. Did I make any beginner mistake, or is this a case for a PN to the mods?
Thanks in advance.
SE
05-09-2017 08:34 AM
Another option is to use your mobile device, and daill 611. There is an option to add vouchers in this way.
05-08-2017 11:47 PM
05-08-2017 08:45 PM
Yes, they are 12 digit numbers. Try redeeming using private/incognito browsing mode.
05-08-2017 08:45 PM - edited 05-08-2017 08:46 PM
Hi @SE1!
If you tried both and made no mistakes, then I suggest contacting the mods!
I suggest you send them a private message. Be sure to include your Public Mobile phone number and voucher number&pin as well as a detailed description of your problem. Click here to know how contact them. They are available Mon-Thursday from 9am to 9pm and Friday-Sunday from 9am to 5:30pm (eastern time). They usually respond pretty fast to help requests!
I hope your problem will be solved quickly 🙂
