09-14-2021 07:34 PM - edited 01-06-2022 03:31 AM
I have been prompted for a PUK (2nd time this has happened on the same phone) and am trying to submit a ticket, but logging into the My Account verification is resulting in a "error login in" alert. I have reset my pw several times and nothing seems to allow me to submit a ticket.
09-14-2021 11:45 PM
Contact Customer Support Agent or the blurb on the bottom right to start a ticket.
09-14-2021 10:47 PM - edited 09-15-2021 12:14 AM
@cvf1 wrote:I have been prompted for a PUK (2nd time this has happened on the same phone) and am trying to submit a ticket, but logging into the My Account verification is resulting in a "error login in" alert. I have reset my pw several times and nothing seems to allow me to submit a ticket.
Are you using the same SIM card as last time this happened? If so, the PUK should be the same as before if you still have the message from the CSA that contains it.
09-14-2021 08:16 PM
You can submit on this Community by clicking on the SIMon chat bubble and type in create a ticket to reset your PUK.
You can try a different browser and go in incognito to login your Self Serve account.
09-14-2021 07:42 PM
@cvf1 Just verified I am able to login using my community account when submitting a ticket through SIMON. Are you able to take a screenshot of the error? If yes, you can submit that to CS Agent.
To contact them, you can also reach out to them sending a private message directly to @CS_Agent
09-14-2021 07:39 PM
Where To Find Your PUK
A Personal Unlocking Key, or PUK code, allows you to reset your SIM card’s PIN number, after you’ve entered an incorrect PIN three times. To get your PUK code, please start a conversation with our virtual assistant, SIMon, to submit a ticket to the Customer Support Agents by clicking here link..
Here’s How To Contact Customer Support Agent by CS_Agent,
Good Luck....
09-14-2021 07:37 PM - edited 09-14-2021 07:40 PM
@cvf1 so, you connect logon to My Account at all?
You sure the password is correct?
If you think the password was correct, maybe it is a browser issue. Try to use another browser, or use Incognito mode or try on another machine.
If you really cannot logon, you can try to reset password using the Forgot Password link
or since you cannot open ticket with Simon, you can message PM Customer Support Agent directly with your issue or with resetting My Account credentials
