Error 38
04-22-2019 11:01 AM - edited 01-05-2022 04:31 AM
Everytime I try to send an international text to Portugal, I get an error 38 message and the message doesn't send. Does anyone know why this is occurring?
Joining Public
05-03-2019 02:18 PM
@computergeek541 wrote:
@Malves wrote:Problem solved.
GPS as to be on.
I'm glad that you were able to get your text messaging working, but GPS is not required to send SMS messages. I believe that this could have just been coincidence. If you now turn your GPS off, does your text messaging still work?
Ture that GPS doesn't have to be on to send SMS, because phones without GPS are still able to.
My guess is that, with GPS is on, the phone knows its physical location, so that knows what prefix to add in front of the country code.
As a general rule, simply use + as a prefix instead of any specific numbers.
04-30-2019 06:10 PM
GPS as to be on.
04-30-2019 10:19 AM
Problem solved.
GPS as to be on.
04-22-2019 01:01 PM - edited 04-22-2019 01:02 PM
@hycm53 wrote:
@Malves wrote:Everytime I try to send an international text to Portugal, I get an error 38 message and the message doesn't send. Does anyone know why this is occurring?
Dial 011 351 +area code+ phone number.
@Malves That error means that there is something wrong with the number you are using. You need to make sure you have the correct number area code + number and just manually enter it as per @hycm53 recommendation above.
04-22-2019 12:52 PM
04-22-2019 11:33 AM
well, try sending message locally. If it works, then I think it is the international prefix.
04-22-2019 11:23 AM
Try looking through the messaging app settings. It is possible that a setting may be interfering with outgoing sms.
04-22-2019 11:06 AM
what prefix did you use? Try to use +351 instead of 011351.
