Emergency call only - CS agent
Bclarks
i need help to get my phone working ,not sure but i can only make emergency call only , and something to do with the network
2 REPLIES 2
@Bclarks
I would also suggest you download the TextNow app or the WhatsApp to make free calls and text when connected to wifi or your data just as additional backup.
@Bclarks
Check if there is any network outage in your area:
https://www.telus.com/en/bc/outages
Also, login My Account to check if your account is active
Try Reset Network Settings after a device reboot.  And if you have a physical sim, you might also want to check if your sim card works on another phone
If nothing works, it is best to engage support for further assistance.  Please open ticket with PM support:
1. Open ticket via Chatbot (need access to My Account): At https://widget.telus.tiia.ai/publicmobile/publicmobile.html
    Start by typing "Submit a ticket", then click "Contact Us", then "Other", then "Log In", finally click "Click here to submit a ticket ↗
    (if you cannot receive 2FA via SMS, click "Didn't Receive code" or "Resend Code" and choose "Send email" to get 2FA)
