04-14-2020 01:57 AM - edited 01-05-2022 10:21 AM
Why when I try to set up a new plan it tells me my email isn’t available and to use a new one (I only have one email)
04-23-2020 03:05 PM
@Pawprints1986 wrote:Wouldn't using an alias mean you can't confirm your account? Or get any emails about the community or others from PM?
@Pawprints1986 No to all you asked.
04-21-2020 08:06 AM
I was asking question concerning using another email to set up an other account (a friend was setting up account) and was getting email already used (when it actually wasn’t already used)
problem solved account was set up using email site said couldn’t be used
04-14-2020 10:20 AM
As to what @computergeek541 said, with gmail its easy to make a alias. Maybe some one can shed light on if it does actually work with PM what i will describe below. To make a gmail alias, just put a "[email protected]" after the first part of the email address. You can replace "anything" with what ever you want to use. The plus sign makes it an alias. As to how someone explained it to me, if you subscribe to a online newsletter.... just put the"[email protected]". If you get mail from that address, you know it came from there or they gave away your email address.
Another thing one can do is to have a second email account, and have it forwarded to the primary email account, if you want.
04-14-2020 09:48 AM
@DebMacD wrote:Why when I try to set up a new plan it tells me my email isn’t available and to use a new one (I only have one email)
Is this so you can have a second phone in your household?
If it is; go to Gmail here ---> https://www.google.com/gmail/ and set up a new email to use for subsequent phones.
Now if you are just trying to change your existing plan then you can do that in your self serve account:
here: --> https://selfserve.publicmobile.ca/Overview/
04-14-2020 06:08 AM
@DebMacD personally, I like having a free Google email account on my Android phones. It gives me 15 gigabytes of space, which allows me to back up my contacts etc there. You can also forward this email to your other email address. Here are 2 articles on Gmail accounts.
Stay safe.
04-14-2020 03:06 AM
Is this new plan a second plan? If so you will need to either use an alias email such as with gmail or create a new email, there are a lot of places to create email accounts.
04-14-2020 02:21 AM
@DebMacD Each account requires a unique email or an email alias of the email that has already been used.
04-14-2020 02:10 AM
04-14-2020 02:02 AM
This means that someone has already set up a Public Mobile account in the past using that e-mail address.
By some chance are you trying to activate a second account? If so, you need to use a different e-mail address. A G-mail alias can be used to make it appear that you have more than one e-mail address or there are many free web-based e-mail services such as G-mail, Hotmail, Yahoo, etc.
04-14-2020 02:01 AM
You can only have one email per account.
