01-13-2023 07:17 PM
My email for my account has been deactivated. So I cannot login to my account.
01-13-2023 08:15 PM
01-13-2023 08:10 PM
01-13-2023 07:39 PM
HI @Naomi5683 if you still have the phone service, choose to send the 2FA code to your phone
if not , then you can open ticket with CS agent and they can help to change to another email address
at : https://publicmobile.ca/chatbot.
First type Forgot Login,
01-13-2023 07:32 PM
If you're having issues logging in, be sure to use an incognito or private tab to log into the self serve site as the site has terrible caching issues.
Once on the site, to get a refreshed version of the page, try tapping the highlighted area when logged into self-serve for a refreshed page version:
01-13-2023 07:18 PM - edited 01-13-2023 07:19 PM
Yup, you can still log in, @Naomi5683
The e-mail address is just a USERNAME, it doesn't have to be for an active e-mail account.
If you forgot your password or other login credentials, then you'd need to deal with customer support to have the e-mail address changed.
Here's how to reach them:
