Email code
Aidenjjjj
I can’t login to the app with the email code it keeps saying it’s wrong
dust2dust
If you're using an Android then you can clear data and cache in the app instead of fully removing/reinstalling. I don't know about iphone.
JRod
@Aidenjjjj
Very strange but at least the website allows you to login,
Can you try deleting the app. Clearing the cache and browsing data from the default browser on the device and then re-installing it?
Aidenjjjj
I didn’t copy and paste it and it works to logging in the website but not the app
JRod
@Aidenjjjj
Are you a new or an existing customer? If you are new has your account been 100% setup?
Also make sure you are typing the code in and not using autofill as that does cause issues sometimes.
