12-26-2022 05:17 PM
I don’t know the email address associated with my account
how do I figure it out
12-27-2022 07:35 AM
The problem is I don’t know the email…,I’m chatting privately now with a rep but they keep asking me the same security questions over and over again
12-27-2022 12:21 AM
If you setup your Community email same as your account email.
Just click on your avatar on the top right then My Setting and it will show your email.
12-26-2022 05:34 PM
@NashMc14 you can try to use the Reset Password link there. Put in any possible email address and see which one gets the email from PM to reset the password
If that does not work, then open ticket with PM Support and they can look it up for you:
1. Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
