11-16-2024 04:41 PM - last edited on 11-16-2024 08:20 PM by computergeek541
Trying to get set up, but Eversafe doesn't recognize my email address. I believe it's because the Top Level Domain is uncommon....it's not a .com or .ca
Help! I don't want to have to open up a generic Gmail account just for one service....I'll never be able to remember that it exists or what the password is for it!
11-17-2024 01:08 AM - edited 11-17-2024 01:09 AM
Depending on your device ( Apple or Android) set up an email that you will use with their apps with something like janesphone2@gmail.com and choose a relatable password that you can remember but using both small and big letters, numbers and a symbol or two. Then store it on a cheatsheet somewhere safe or a locked folder or 2 locked folders ( one with the email and the other with the password.)
It's best that you don't use you regular email for your public mobile email as it makes it harder for hackers to access your online accounts when they don't share the same email as your mobile provider phone's account.
11-16-2024 06:37 PM - last edited a month ago
hi @EndlessFootstep look like the reason for the problem is not EverSafe actively rejects .quest . It is just the system setup does not allow Top level domain with more than 4 characters.
But with PM, it is unlikely they will make change anytime soon to accommodate
11-16-2024 06:27 PM
.quest
It's a TLD that's been available for more than 10 years, though I'm not sure how long ago Quest opened it up to public registrations.
11-16-2024 06:11 PM
Agreed. Support can't bypass a system limitation.
11-16-2024 05:10 PM
hi @EndlessFootstep what is the top level domain?
I think to avoid spam, PM might have set some restrictions with the domains, please check with support agent to confirm by message them here
11-16-2024 04:58 PM
Don't you have a smartphone with a Gmail or Apple icloud account?
11-16-2024 04:52 PM
@EndlessFootstep wrote:Trying to get set up, but Eversafe doesn't recognize my email address. I believe it's because the Top Level Domain is uncommon....it's not a .com or .ca
I am confident if you contact a CS Agent to share your concerns, they will tell you to just open a Gmail account.
