10-24-2017 03:00 PM - edited 01-04-2022 02:48 PM
10-27-2017 12:02 AM
Thank you, I will check it out. I wanted to update my plan early so I could have a better chance at getting the data promotions that are on now
10-26-2017 10:03 AM
@emilygeorgia wrote:I think the feature used to be available through self serve, I remember when I signed up with a 10 day texting only plan to test my phone, and then 2 days later changing to a new 30 day plan with data. Maybe they will bring it back
I believe it is still possible to switch plans before expiry.(I havent looked at self serve in a while)
Only issue is if you are on a grandfathered promo plan. You cant select the same plan with discounts anymore.
A mod will need to assist with that.
10-24-2017 07:48 PM
10-24-2017 04:17 PM
@NDesai that would be a great feature to add to self-serve for sure...
10-24-2017 03:52 PM
@closng wrote:@xCameron94x That's interesting, didn't know you could do this!
Yup, mods can always do it. I can only wish for if they can enable early renewal from self-serve account.
If you need to contact PM Customer Support Agent, Start a Chat to Create a Ticket OR visit the Get Help page.
10-24-2017 03:37 PM - edited 10-24-2017 03:37 PM
10-24-2017 03:01 PM
Yes there is. You will first need to put funds into your account equal to that of your plan cost (also known as a manual top up). After you have topped up your account, contact the mods, and they will be able to early renew your plan for you
