ESIM compatibility
catschaar
Hi - I am trying to set up my phone now that I have purchased the 20$ a month plan, but your app says that my phone is not esim compatible. However, it is esim comapatible (Iphone 13). What do I do?
1 REPLY 1
@catschaar  You might need get physical SIM card first then change back to eSIM afterwards but you need to confirm with support to help
send  a  private message   To CS_Agent
https://productioncommunity.publicmobile.ca
