E-sim
Nila31
Help!
when I registered online it said my phone is e-sim
compatible! However when I logged onto the app it saying it is not. I did not receive a QR code either.
how do I fix ?
@Nila31
The iPhone 15 Pro Max is eSIM compatible. I have the iPhone 13 Pro Max, iPhone 14 Pro Max and the iPhone 16 Pro Max but I prefer the SIM so I can pop it into which ever iPhone I want. Rather than purchasing a new eSIM when I want to switch iPhones.
Contact a CS_Agent to help you with the eSIM issue.
I’ve heard that this is common with the latest iPhone when activating a new eSIM.
Nila31
Hello!
it’s an iPhone 15 pro max. I just recently updated the IOS
@Nila31
What is the make and model of your phone?
hi @Nila31 check with. support agent first, they might be able to send you a eSIM QR
you can submit  ticket by direct message:
