E Sim not working
larad1
Hi, I activated my Public Mobile service and approved my number transfer from Freedom.
I accidentally added and deleted an eSIM, and now there is no Public Mobile plan showing under Cellular on my iPhone.
I’m unable to submit a ticket through My Account.
How do i activate my service and transfer to Public?
8 REPLIES 8
larad1
thank you so much!
ok., then the Freedom side is good
check with PM first and see what they suggest
larad1
Yes i got replied yes to the freedom message. i still have my physical freedom sim in my phone
slusagm
@larad1
and you got the text from Freedom to approve the port yet? if you have not got it yet, you will need to rebuy a Freedom sim so you can get the text and approve the port.
larad1
Hi, thanks for your response. i accidentally added freedom e-sim but deleted the freedom one after. I cannot see public in my cellular though. Not sure if that changes anything
larad1
Hi, sorry i miswrote in my post. i accidentally added freedom e-sim but deleted the freedom one after. I cannot see public in my cellular though. Not sure if that changes anything
hi @larad1
you will need to ask PM to help.  And to be honest, you might need to go back to a physical sim first, have it all setup and buy esim.  But check with PM support agent and they will check the situation.
 you can submit  ticket by direct message:
slusagm
could be trouble if you deleted the PM esim.
you have to ask PM to help.   Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
