06-06-2026 11:42 AM
06-06-2026 12:21 PM
See if you can login PM app and get a free replacement eSIM.
Login the app in the phone. If you cannot receive 2FA , click Didn't Receive code or Resend code and select Send email or Send Voice Message. If you choose Send Voice Message z you can retrieve the 2FA VM message by calling yourself from another phone
If you can login, go to Account> Purchase Sim card, and choose eSIM
06-06-2026 12:02 PM
Thanks - new to the community but not new to public mobile. Thanks for providing me with a link to submit a ticket.
06-06-2026 12:01 PM
Thanks - tried this but it didn't work.
06-06-2026 11:50 AM
the CS agent tag should be @CS_Agent , but they don't monitor post here, you have to open ticket
but for your problem, you just joined? make sure you removed old sim card, disable old esim.
and make sure PM esim is the only one enabled, set with label Primary.
Then Reboot phone and click Reset network settings and test again
if same, then submit a ticket with CS Agent and they will help. You can submit ticket by direct message:
06-06-2026 11:47 AM
@Sam_I_Am wrote:My e-SIM has no signal despite the account being active @csagent
Hi @Sam_I_Am
Try this. Go into settings, make sure it's the only eSIM you have there and it is set to active. IF you have a secondary eSIM or SIM card, make the Public Mobile eSIM your primary.
If you only have the one eSIM, go turn on Airplane Mode for 1 minutes. Then turn it off and reboot your phone. This should bring you back to the network.
