Dropped calls
Jeanneb
Why on the middle of a call does my service/phone drop call?
cavemantoronto
It could be anything.
Poor signal because of bad antenna in phone or tower too far (on your side or other person's side)
Network issue
One person hanging up by accident
Time limit for call at either carrier
Running out of minutes
Phone software crashing
I think you'll find that signal will improve outside on a patio or deck. You can use an antenna booster, but they can get expensive.
Jeanneb
Could be right usually at home and i live on cement apt building.
hairbag1
Maybe you're in a fringe area where cell signal isn't too strong. Does this happen often ?
totalUser
There were some issues with dropped calls in the past, it was affecting 15 plans with calls dropped around minute 7 and done other plans would cut off at about an hour. This problem couldn't be fixed by users, they had to contact moderators. The best is if you click on the question mark and ask to talk to human', you will have an option to creat a ticket
