Dropped calls
05-25-2024 03:33 PM
Hey Everyone. When anyone calls me from a 705 area code and I answer the call gets dropped and if I don't answer they can't leave me a voice mail as it hangs up on the caller
Its only from 705 area codes, all others are ok
Any help would be appreciated
Cheers Rob
Service
06-14-2024 07:52 PM
No luck that didn't work. Had to wait till I received a call from a 705 area code
05-25-2024 04:22 PM
I changed my network to public mobile and I have a android phone
Let's see if that works
Thanx a bunch
05-25-2024 03:38 PM
Hey @robbie101
Try this. Go into your network settings, turn off automatic and pick Public Mobile. Then reboot the phone.
Also, make sure all your software for your phone is updated. If it's an iPhone, make sure you turn off block unknown callers. That's a big issue here.
