Doubled up subscription.
CDeGuire
Hi, on August 7 my payment went through as usual. The next day I upgraded and was charged for the upgrade, no problem. Would be nice to get a refund instead of paying for both. This month I was charged the old rate again and in two days will get charged for the upgrade. Please help!
@CDeGuire
Try again incognito/private mode
And or lap top /computer
                    OR
simply try refreshing the page to check data plan / mins / add ons
if it still not right submit ticket with support using this direct link
send a  private message   To CS_Agents click
@CDeGuire wrote:
Hi Handy 1, thanks for you prompt reply. I'm ok with not getting a refund last month but I don't know why it took the old subscription amount if I upgraded. Do I need to delete the old subscription?
HI @CDeGuire
it shouldn't take your old amount if it already taken the new amount once earlier
Please use Incognit/Private/Secret mode on your browser to check once more to avoid cache issue
if still shows the old plan and old amount charged, submit a ticket with CS agent:
CDeGuire
@CDeGuire  Sorry PM is pre paid and no refunds , that’s why it’s advised to change plans on next renewal and not immediately or you lose money in your current cycle
Change plan in 3 easy clicks
Once you find plan you want be sure to (change on renewal )So you don’t lose money on current cycle
