Don’t remember login
Vasconez
How can access to my account to change my credit card information if I don’t remember my login or password of my account
2 REPLIES 2
You could cycle through the e-mail addresses that you might have used for the password reset option.  You'll receive an e-mail from Public Mobile with reset instructions if you enter the correct one.
@Vasconez
You will need to contact a CS_Agent to help you access your account by private messaging or SIMon Chatbot.
