08-26-2016 04:14 PM - edited 01-04-2022 03:07 PM
If I got a samsung galaxy note 5 from Rogers. Can I use it with PM?
Many thx!!!
Service
08-26-2016 07:54 PM
Hi @trdtdtd, welcome to the Public Mobile community! As @McLaren has mentioned, your phone should be fully compatible, but will require unlocking. You could pay Rogers to give you an unlock code, or there are other sources available online that can be much cheaper. Try searching around the community, there are numerous suggestions of unlocking services to use.
I hope you decide to give PM a try. Do let us know if you have any other questions or concerns.
08-26-2016 04:24 PM
Yes it Will work in pm. You will just need to unlock it first.
