04-08-2024
05:30 PM
04-08-2024
05:32 PM
computergeek541
I'm looking to port from Koodo prepaid to Public, but wanted to know if porting causes any issues generally? I can see posts from folks have trouble with their SMS or receiving OTPs. Is that a known issue?
Context: Porting is more of a convenience for me at this point than a neccessity so I'd likely avoid it if there are issues.
04-08-2024 08:23 PM
Hi Shaz21
I just signed up for a Public Mobile plan, signed into the PM app to download an eSIM and then I couldn't receive any SMS msgs. After confirming it wasn't a number porting issue from Bell, I realized my phone was still using my Bell SIM. I answered No when I should have answered Yes to the question, do you want to use 2 sims on a single device? As soon as I tapped on the PM sim in my network settings to make it my preffered carrier, all my texts flooded in.
I hope that helps.
04-08-2024 05:33 PM
@Shaz21 wrote:I'm looking to port from Koodo prepaid to Public, but wanted to know if porting causes any issues generally? I can see posts from folks have trouble with their SMS or receiving OTPs. Is that a known issue?
At the moment, there appears to be some type of issue going on for new customers not being able to use SMS servcies properly. I have not seen any statement by Public Mobile about these issues yet.
04-08-2024 05:32 PM
Normally @Shaz21 porting SHOULDN'T be an issue. But over the last few weeks, Public Mobile has been dealing with issues on texting yet hasn't said anything in the announcement section. If you do port over and your texting isn't working, you'd have to create a ticket.
To Submit a ticket, please click the following link to access the Public Mobile Chatbot: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type: Customer Service Agent
