Does Note 9 960U work with public mobile?
obi
Does the Note 9 model 960U work with public mobile?
I saw a post saying text/calls works but does LTE data work fine on it?
thanks
Rickray4
Mine works fine.
Staliger
@obi Yes, as was mentioned previously, this device will work with PM. Welcome to the community and hope you will enjoy its savings and service.
thanks
Although have both HSPA and LTE compatibility is desireable, LTE compatibillity is not required for service at Public Mobile. If anything, the HSPA (3g) abiltities are far more important and phone calls won't work without it. The HSPA network is also text message and data capable.
gblackma
Yes according to this site  https://www.gsmarena.com/samsung_galaxy_note9-9163.php its 100% compatible its the US version and has all the required 3g and 4g LTE bands.  Make sure its unlocked. Welcome to the community.  Stay safe.
geopublic
@obi  That's the North American model and as mentioned will work without any issues.
Dunkman
@obi
This phone should work fine with PM including data.
3G bandsHSDPA 850 / 900 / 1700(AWS) / 1900 / 2100
 CDMA2000 1xEV-DO - USA
4G bands1, 2, 3, 4, 5, 7, 8, 12, 13, 17, 18, 19, 20, 25, 26, 28, 32, 38, 39, 40, 41, 66, 71 - Global
1, 2, 3, 4, 5, 7, 8, 12, 13, 14, 17, 18, 19, 20, 25, 26, 28, 29, 30, 38, 39, 40, 41, 46, 66, 71 - USA
Public Mobile uses the following frequency bands:
  • 4G LTE and LTE Advanced: 700 MHz, 850 MHz, 1900 MHz and 2100 MHz downlink and 1700 MHz uplink (AWS).
  • HSPA: 850 MHz, 1900 MHz (UMTS).
