Does $15 plan include call waiting feature?
dac13
Under Plans it states "All our plans include these features: Call DisplayVoicemail and Conference Calling." - no mention of call waiting.
But I saw somewhere (can't find it again) that all unlimited calling plans include call waiting.
Does $15 plan include call waiting feature also or is it just all plans except the $15 plan?
dabr
@dac13   I don't believe PM has call waiting for any plans it offers, unless I've missed some info somewhere that is 🙂
Edit:  I did find this link that explains all the features that PM offers and now I'm a little confused because it mentions call waiting but not sure if that is offered by PM:  https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/How-To-Use-Your-Phone-and-Plan-Feature...
@dabr Just found where I saw it...if you go to Change Plans then it states this at the top "Voicemail, Call Display, Call Waiting, Call Forwarding and Conference Calling are included in all Unlimited Talk plans."
@dac13  Thanks for the info, so it's only available for plans with unlimited talk which is too bad as I also have the $15...oh well 😊
dac13
JoyLuck
@dac13
Call Waiting
Call waiting allows you to put a phone call on hold to answer another incoming call on another line. This feature is different on every phone, but generally, an icon will appear allowing you to pick up another call. If this doesn’t clear things up, we recommend checking your phone’s user guide for precise instructions.
dabr
