Do i have to turn 4g off on a 3g plan?
1981stevenson
Do i have to turn 4g off on 3g plans?
As mentioned, leave the LTE setting on your phone enabled, just making sure that your phone isn't set exclusively to LTE (3g is required for voice service).  Most phones these days don't allow you mistakenly it like that in the regular settings menu anyway.
Even if Public Mobile weren't allowing access to the LTE network (which they are), there still wouldn't be any need to disable it. The phone would automatically select the best possible connection available, regardless.
matbasm
@1981stevenson, there is no need to do so.  Public Mobile 3G is actually LTE(4G), running at 3G speed.
1981stevenson
Thanks
LEGO
@1981stevenson
No, leave 4G LTE on, as Public Mobile’s 3G is throttled down 4G LTE.
