Disabling a Voice Mail
Munacojet
How to I disable my voice mail on Public Mobile?
self solution removed
@Munacojet  You can’t totally disable it but you can do extended greeting and no one can leave messages
Extended absence Follows the following flowchart:
[3]Greetings --> [4]Extended Absence --> [7]Delete
hi @Munacojet
you cannot really disable VM, but there is a workaround,
You can turn on Extended absence, which is pretty much same is disabling VM:
  • dial into your voicemail and log in with your PIN.
  • In the main menu, press 3 (manage greetings),  then 4 (manage extended absence greeting),
  • then 2 (record a new extended absence greeeting) and record a message that indicates to your caller you are not accepting messages.
  • Then press 4 to turn on extended absence
  • Finally, press 5 to dissallow anyone to leave you a message.
Munacojet
Sorry for the typo.
How do I disable my voice mail on Public Mobile?
