Disabling Voicemail
fk8338
My plan is voice only and voicemail included.  How can I disable the voicemail feature?
8 REPLIES 8
bakayaroh
from what I have read about the 10$ plan is even forwarding your call counts as 1 min in your plan.
mimmo
it could be, but "voice only including voicemail" suggests unlimited calling.   The only  limited calling plan is the $10 talk and text 50 minutes 50 sms plan
Effort
I figured the only reason why they want to disable it is because it uses minutes to retrieve the voicemails.
mimmo
@Effort the original poster has a talk ony plan and asked how to disable voicemail completly as they do not want voicemail at all.
@Effort wrote:
@mimmo wrote:
anther option is to change the voicemail forwarding number to a number that is not in service. i believe that is what a couple people on the $10 plan have done.
Instead of sending it to a number that isn't in service, send it to a free VOIP number like Fongo or Talkatone. That way you still get the voicemail and it's free.
Effort
popping
That is a good choice for the $10 plan with only 50 minutes.  You don't want to the voicemail announcement eats up you minutes.
mimmo
NDesai
@fk8338 You cannot. However, you have an option to enable extended greetings. To do that, here is the guide: https://productioncommunity.publicmobile.ca/t5/Getting-Started/Re-Disable-Voicemail/m-p/213805/highl...
