01-30-2021 11:48 AM - edited 01-05-2022 05:04 PM
Funny one here, got a new card, didn’t change it here. So auto pay didn’t work, so I changed my card to the new one, and now it’s saying on my account, I have no amount to pay. I try to pay manually, and put in amount due, and it says I have enough balance. Which is wrong I’m trying to give you money haha. Just need someone to fix that for me that’s be great
01-30-2021 02:04 PM
@zachjack DO NOT CHOOSE 'AMOUNT DUE' IT GLITCHES OUT. USE 'OTHER, ENTER THE DESIRED AMOUNT!!!
01-30-2021 01:39 PM
Hi @zachjack
If you have enough available funds to pay for your plan of choice, then click the "reactivate" option on the self serve page.
If that still doesn't work, wait 1 FULL hour, clear cache and cookies, open an incognito tab, and try again.
If you've tried all that and it still doesn't work - contact a moderator.
To contact a moderator, there are 2 methods:
01-30-2021 11:58 AM
@zachjack do you have all your services?
01-30-2021 11:56 AM
@zachjack Does your phone work?
Does your account say Active or Suspended?
01-30-2021 11:55 AM
@zachjack Clear cache and cookies and try to add Other amount (your plan cost +1$)
