10-03-2022 09:18 AM
I purchased a US talk and text add on. I have receipt and can tell from my online bank statement that the purchase went through but I do not have the add on when I look on my public mobile account and can not text or call
How Can I get this fixed? Is there a way to contact someone other than AI?
10-03-2022 11:45 AM
Thanks so much. I followed your instructions and everything has worked out great. Much appreciated.
10-03-2022 09:57 AM - edited 10-03-2022 09:58 AM
@AnneSpringle wrote:I had the same thing happen to me this week. I thought it hadn't gone through, so I paid again and have now paid twice for the same thing. It is so frustrating. Surely, there is someone we can call?
@AnneSpringle You cannot call them but you can open ticket with PM Support. They will check and if it got purchased twice, they likely will reverse the transaction without problem.
Please open ticket with one of the 2 methods below:
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
@rlid open ticket with PM Support as well and they can confirm and action accordingly
10-03-2022 09:56 AM
10-03-2022 09:41 AM
thank you I have done that. But when I check my account it shows that I have no US add ons listed. So Do I need to repurchase? Can I get a refund? I see that another customer had the same problem but I did not see if there was a solution
10-03-2022 09:35 AM
Then all you can do is contact support. If you clicked the spinner or used private mode and checked payment history and see it there but it doesn't show in your add-ons then there's nothing else to do but wait.
Do all this checking on both accounts.
10-03-2022 09:32 AM
Thanks - but that doesn’t work The real issue I think is that when I check my account the add on is not listed So it isnt there But I have receipt and online banking shows payment has gone through. it has been a day since I purchased it
10-03-2022 09:31 AM
We recently saw someone else doing back to back add-ons for different accounts having strange things happening. It's possible that the system cached things from one account login to the other. Can you look in your payment history to see what is shown. Use private mode. Log in one account. Click the little spinner refresh icons lower down. Check payment history. Then log out and close browser and open private mode again and log in to the other account and do the above for this account.
10-03-2022 09:26 AM
@rlid you should be able to see it when using Incognito mode to login to My Account.
And remember to try to connect to T-Mobile for the Talk to work. If the phone cannot connect to T-Mobile by itself, try to override Automatic network selection by manually connecting to T-Mobile network
(Your Text option can actually work on both AT&T and T-Mobile LTE network, but since you have talk and it needs T-Mobile 2G network, it is better to simply connect to T-Mobile if you can)
10-03-2022 09:25 AM
thank you I have done all of that. I purchased an add on for my husband at the same time. His works
10-03-2022 09:22 AM
@rlid , can you please recheck your account using incognito mode on your browser. You might be seeing a stale cached version of your self serve account. In the event that the add-on is not there, you will need to use the chatbot link to initiate a support ticket to sort things out with the CSA team.
10-03-2022 09:21 AM
Click on the little spinner refresh icons lower down to see if things show up. Or use private mode. Are you in the states? Manually connect to T-Mobile.
