Delay US roaming Add-on
Marekss
I purchased US $20 Roaming package would have never guessed is starts right away. Why can't I pick a future start date. How do I delay a few days. Also where can find the 1GB US add-on. Ill use 250mb just using maps.
darlicious
@Marekss
You will need to contact customer support to remove the add on and credit your account. Leave a detailed message and explain your honest mistake. You can then add the US Roaming add on upon departure or arrival in the US using wifi or by calling 1 855 4PUBLIC and enter your 10 digit phone number but you will need to know your 4 digit account pin # to use this option.
Here is some info on US Roaming add ons that you may find helpful....
Spoiler
Here is some info about US roaming add ons that should help you.....
  1. While you have to have an active plan to purchase and use US roaming add ons the type of plan you have does not affect the roaming add ons features.
  2. US roaming add ons start the moment you confirm and submit your purchase in your self serve account and expire 240 hours later (10 days×24 hours).
  3. You can pre-load the funds needed to purchase the add ons in your self serve account so you only have to log in, select the US roaming add on and then confirm and submit your purchase.
  4. Wait til late as possible to purchase since they are immediately valid so on free wifi at the destination airport or stopping shortly before the border at mcd's or timmy's to buy the add on while on free wifi.
  5. If you are staying longer than 10 days you must wait a minimum of 24 hours to purchase the same US roaming add on or contact the moderators to add it before the waiting period ends.
  6. If you have two US roaming add ons with a talk feature that overlap the talk feature basically gets disabled. Avoid this....but you will have to get one removed by a moderator to get your calling feature back if this happens.
  7. After purchase reboot your phone and manually select either at&t or T-mobile to get better reception. Some areas have better coverage by either provider so when travelling around the US you will be better served by choosing the provider with better signal strength by locale.
  8. You will recieve incoming texts without any US roaming add ons. Adding the fongo app and textnow app for use on wifi are good to use for a back up plan or you could call forward your pm phone # to your fongo # before you leave Canada and purchase just the US data roaming add on. Fongo also works on mobile data (1 min=0.5mb/100 min=50mb) so you could still recieve incoming pm texts, recieve incoming pm calls to your fongo #/app, outgoing calls from your fongo number and outgoing  texts from textnow for free or small fee from fongo.
  9. All US roaming add ons have either unlimted text, talk or both. Only data has limits depending on your purchase 250mb/500mb/1gb. Once the data is consumed it will just stop you could then purchase different roaming add on, wait 24 hr to buy or contact the moderator to buy the same US roaming add on again. (* except talk as previously mentioned.)
Happy travels and Stay--Safe!
Please note currently due to the decommissioning of the 3G network in the US by pm's roaming partners at&t has already begun this process but as of March 3rd 2022 still has some areas that are still served by the 3G network. T-Mobile has an end date of July 1st 2022. This will affect the ability of pm customers to send and receive voice calls and emergency service such as 911 while in the US and using pm's US roaming add ons. The current work around is to download a voip app such as textnow or fongo for use while on wifi or mobile data for voice calls when in areas no longer served by the 3G network which will eventually include all areas served by at&t and T-Mobile.
The suggestion of downloading Google maps @HALIMACS  for the areas you will be visiting is an excellent idea to conserve your data.
HALIMACS
@Marekss
I would recommend downloading maps from Google maps for offline use.  See this article: https://support.google.com/maps/answer/6291838?hl=en&co=GENIE.Platform%3DAndroid
These can be used completely offline and areas can be overlapped to serve the areas you will be travelling and needing maps.
When you download them they will take into account the current roadways, however you will not have real-time traffic data.
@Marekss - you cannot delay the 10 days of the Roaming addon.
Are you not in the USA yet? If you didn't need the Roaming addon yet, and you didn't know it started right away, you could ask if CSA can credit you the value and add the funds to your Available Fund area to use when you are ready.
To contact CSA, two methods are found here: https://www.publicmobile.ca/en/on/get-help/articles/contact-an-agent
edit, sorry, you also inquired about the Roaming 1GB addon. It is there under the addon section to purchase: https://selfserve.publicmobile.ca/Overview/plan-and-Add-ons/ChangePlanLandingPage/?PageRedirect=Redi...
You can also call 611 to see what is available to purchase as well. I am not sure if all are listed when calling 611 though.
