Data
Andrewweit17
I just renewed my service. I had gotten the text about the 2gb free and 500 int talk minutes so i accepted it and they added it to my account. I just used the 2 gb all up and now NONE of my data works. My original plan has 20 gb of data but it doesnt work. My calling doesnt work either i seriously have no idea whats going on. Can someone help me?!
9 REPLIES 9
Andrewweit
I have an iphone 12 pro max how would i find this and set it in sync?
CGO
if both voice/data not working, reinstall sim/phone, set 3G network only, then contact CSA.
dust2dust
Do you have a data usage block setting on your phone? If so it needs to be sync-ed with your Dec 8 start date.
And if you click on that same little spinner icon under the shop add-ons as shown by hairbag1 then you might see the freebie 2gb too. I would very much doubt it got used before your plan data.
Andrewweit
walker1
@Andrewweit17
You might want to get in touch with a Customer Support Agent and have them look into your sim card and provisions.
Use the Chatbot Simon to get a service ticket started first and then ask them about your data.
Andrewweit17
Andrewweit17
Yeah ife reset my phone 70 times and it still doesnt show a difference but my cycle just reset and there is no way i used 20gb in 4 days
WolverineCaz
Restart device. Log in to see what your usage is at now (There may be a delayed glitch when adding the promo). If it still doesn't work, have a chat with SIMon https://www.publicmobile.ca/en/on/get-help
