04-26-2020 03:46 PM - edited 01-05-2022 10:32 AM
04-26-2020 06:05 PM
@enas4jesus Did you solve the issue? Everything is clear and good now, or you need further help? Let us know, thanks.
04-26-2020 04:36 PM - edited 04-26-2020 04:42 PM
@enas4jesus wrote:I paid for last month and this month and I'm not getting my data
In order to get working data, your APN setting must be correct.
https://apn-canada.gishan.net/en/apn/public-mobile
1. Restart your phone with data enabled and PM SIM card inserted to let PM SIM card to configured your APN settings automatically. If this failed to fix it, you need to update your APN setting manually using the above link as reference.
2. Check your data usage line on your overview page after login.
I used 16.514 MB out of 250MB from my plan. If you do not see your data usage line, you had used all your data.
| Data & Add-Ons | Amount Used |
$0 Free Holiday Giveaway: 1GB Add-on | 140.206 / 1024 MB |
$0 Free Holiday Giveaway: 400min INTL Long Distance (incl CA & US) | 1 / 400 MIN |
100 Minutes Canada-Wide Talk | 4 / 100 MIN |
1GB Promo | 102.004 / 1024 MB |
250 MB at 3G speed | 16.514 / 250 MB |
500 min Canada-Wide Long Distance | 225 / 500 MIN |
Options to get more data:
1. If your current data limit does not meet your 30 days' need, you may change a plan with more data. You can do the plan from self-serve. You get your data back immediately with plan change.
2. If you want to renew the same plan early, you need to create a moderator support ticket using the ? button at the bottom right hand corner of this page. Moderator wait time is up to 2 days or longer. If your next renewal date is up to 2 days away, you may just on data diet for a few days until after renewal.
3. You can buy data add-ons $15 1GB data or $10 200MB data. Expensive option
04-26-2020 03:54 PM - edited 04-26-2020 03:55 PM
Did you purchase an add-on ? It is a two step process, you need to pay and add it to your account. Check your account under data and add-ons.
To purchase Add-Ons using your Self-Serve account, follow these steps:
04-26-2020 03:50 PM - edited 04-26-2020 03:52 PM
If you can't make data connection you will have to coast you apn settings.
First try network reset and restart with sim in
Then try changing them manually, I'll post link
04-26-2020 03:50 PM - edited 04-26-2020 03:51 PM
@enas4jesus can you log into your self service account and see if you have data available? And whats the make and model of your phone? Thanks.
04-26-2020 03:48 PM
Can you log into self service and look at Plans and add ons to see if your data is showing up?
04-26-2020 03:48 PM - edited 04-26-2020 03:49 PM
Please provide more info
Did you try to buy an add-on this and last month?
Is your plan data not working?
Could you please take a screenshot of your overview page, blackout the personal/account info, then we may know what the problem is
