Data
Public2019
Will there ever be unlimited data plan
7 REPLIES 7
sadrms10
Thank you z10user4
 for taking the time to help me out...the phone is my daughter's, the reason for the lack of info currently, I will most definitely use the info you provided.
@sadrms10 wrote:
Acer
 @sadrms10
A more detailed full make/model would have been more helpful as there might also be frequency issues with your phone. But in the meantime..
Find your phone on this list:
Officially Recognized APN Reference
If your phone isn't there maybe these might work:
APN Settings:
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Not set
APN type: default,mms,agps,supl,fota,hipri,dun
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
sadrms10
Acer
@sadrms10 wrote:
I have activated my account and purchased the $40 plan with 5GB on Feb 23rd, but the data still does not work...help! Plus, I have try several times over the suggestion from the Simbot (chatbot)
Which phone do you have @sadrms10 ? It's probably something with your APN settings...
sadrms10
Public2019
That's all I want lol but owell 8gb for 50 plus unlimited is great deal I used to pay 200 for 20g and unlimited
Lieux
Perhaps one day ..but not now with public mobile...Smiley Frustrated
