Data
tazzer
Why can i not get access to my data in which I am paying for
1 REPLY 1
@tazzer what phone do you have? Voice calls working?
Did you enable Data on the phone? make sure Data limit is disabled
Make sure all the old sim cards/eSIMs are disabled or removed, PM sim should be the only one enabled and set with Label Primary.  Then perform a Reset Network Settings after a device reboot and try again
If still fails to connect, let us know the phone model and we can assist further
