Data
Gmuree17
How much data does my current plan offer. I pay $117 every 90 days. I can't find that info anywhere on this site.
Thanks to all for your help
9 REPLIES 9
Gmuree17
Thank you for your answer dust2dust
Gmuree17
That's great, thank you again
Gmuree17
Thank you for your detailed response and your time.
Much appreciated.
hairbag1
@Gmuree17
as soon as you successfully log in to your active PM account, you should see the features of your plan...
It should also show you in your payment tab also
Gmuree17
Thank you handy for your help
Gmuree17
Thank you for your answer but I did not see that when I logged in. Maybe I'm just not used to this site as the older version was very easy to find the data plan
@Gmuree17  If gives you 90 GB to use over 90 days for $117 works out to $39 a month
dust2dust
It's on the first page when you log in to your account. Not here.
