08-28-2019 09:32 AM - edited 01-05-2022 08:42 AM
My plan just rolled over for the month (plus I received the 1G gift of data) and I just received a text message from Public Mobile saying I’ve used 95% of my data. This is impossible and it won’t let me access my usage info on my account. Has anyone else had this issue or know what I can do?! Thanks!
Service
08-28-2019 10:00 AM
@Jsmodgson wrote:@Dunkman Thank you! I am on a plan with only 1G but I rarely use even half of it. Last month was an exception with being on holidays. My guess is that my data counter is not reset. For some reason I can’t get the normal info off of the overview page, I headed there first. I will try the moderator.
You can try to clear cache, try a different web browser or going incognito. Chrome incognito works well with PM website.
08-28-2019 09:47 AM
Sometimes I find history pages in the self serve a bit slow to load, but they eventually do. Try again. Anyway, the information in the overview should suffice if you are trying to figure out how much data is remaining. The data counter does reset when you renew.
08-28-2019 09:42 AM
08-28-2019 09:37 AM
Which plan are you on? Can you access your self service account? Check the data counter on your overview page in the add on section.
There have a few cases where the data counter has not reset with plan renewal. If that is the case, you will need to contact moderator.
The extra 1 GB data has not been awarded to accounts yet. Soon though (within 2 weeks).
Send a private message to moderator through the following link :
