Data usage
RitaW
My data usage shows data being used during middle of night when my phone is charging and I am not using it.  Do you know how this could happen.  This month is the first time I have had this issue
1 REPLY 1
@RitaW
PM does not update the data usage constantly.  In fact, it only update it twice a day.
So, any entry you see is just a total usage between that timestamp and the timestamp of the previous entry.  The early morning usage  you see on the Usage log does not mean it was used in the morning but a total usage for the last 12 hours.
Also, for correct usage reading, always use Incognito mode to login My Account to avoid reading cached old info
