08-06-2024
05:46 PM
08-06-2024
07:06 PM
computergeek541
08-14-2024 05:39 PM
That absolutely worked Ty very much
08-06-2024 05:50 PM
I had the same problem last month. You need to logout of the app then log back in.
Remember to click on Trusted Device so you don’t need to redo the 2FA sent to your phone next time you log back in.
08-06-2024 05:47 PM
@Marko100 could be cache issue first try to clear app cache or uninstall the app and re install it to check . Also note PM only updates the usage 2x a day so your only ever seeing the last 12 hours used
