07-30-2017 09:07 PM - edited 01-04-2022 02:25 PM
Hi everyone,
This is my first time asking a question in the community so I hope I'm doing it right. I'm on the $120 12GB 90day talk/text ($40 per month fall promo from 2016). My most recently statement started May 14 and on July 21 all 12GB of my data had been used up. I have wifi at home and work and this seems strange to use up so much data in 9 weeks time. I purchased a 1GB data add on to get me by on July 21 which expired yesterday. Again being 2+ weeks from my renewal I opted to purchase another 1GB of data around 7pm (EST) last night. I checked my data right now and it's already showing usage of 290mb of 1024mb.
I think there might be some sort of error in tracking and it seems very difficult to view data usage online. After reading some forums I may look into a datatracker app, but I've already started deleting apps, auto-play is off on social media, location services off, wifi-assist is off.
I'm out of suggestions. Is there someone that can look into my account or suggest other ways to limit usage?
Thanks,
Jeff
08-26-2017 04:26 PM
@Pravdivost My issue seems to have worked itself out lately. I've downloaded 'My Data Manager' app to continue tracking and started fresh on my renewal date (Aug 11) and the last two weeks the data has been pretty on par with what PM has shown online. Not sure what had caused the issue last period but it definitely made me much more cautious going forward, I'm always on WiFi at work as well as home so how i managed to use 14gb over three months is baffling.
08-24-2017 04:47 PM - edited 08-24-2017 04:48 PM
08-24-2017 03:53 PM
07-31-2017 09:11 AM
07-31-2017 09:06 AM
@Dougk i wouldn't be overly concerned, as it is only 5Mb of data. Which is basically nothing. The PM data usage is not real time, so you must've done something little before the phone died. Even when you power on the phone, you are connected to data until the phone picks up wifi
I would be more concerned if it showed a variance of 100 MB
07-31-2017 08:45 AM
07-30-2017 11:26 PM
App auto-updates can consume data like crazy. I would defintely limit certain apps such App Store to WiFi only.
You can fine-tune it by going
Settings -> Cellular
Turn off "USE CELLULAR DATA FOR:" for the apps you don't need to run.
Also turn off iCloud Drive using cellular.
07-30-2017 09:40 PM
@shawnie_boy Ok, I'll turn that back on.
07-30-2017 09:39 PM
07-30-2017 09:33 PM
My data manager is by far one of the best data tracking apps, are you sure that maybe updates are not set up to download using data, always set them up to WiFi only, and check your built-in data tracker it should show which app is consuming most of the data
07-30-2017 09:32 PM
@mimmo - I saw that option about renewing early too, so far I've purchased two 1GB add-ons for a steep price lol. I'm gonna try and make this work until August 11th which is my renewal date and hopefully going forward I won't have this issue! Thanks
07-30-2017 09:31 PM
Thanks for the advice, @shawnie_boy, @xCameron94x. I've downloaded My Data Manager app for iPhone and we'll see how this goes. Background App Refresh is off completely and auto-play videos are turned off for Instagram/Facebook/Twitter to limit data usage.
07-30-2017 09:30 PM
you might wnat to ask a mod to actually renew your plan early insted of buying additional 1 gb addons. If you think you will go through 4 1gb addons between now and your renewal date. then it is better to renew early.
07-30-2017 09:16 PM
By "auto-play" do you mean that background processes are turned off? Basically any app can run in the background unless you tell it to stop. Facebook, Snapchat, Twitter, ect are one of those apps that will always refresh constantly with all the new posts throughout the day. Check your phones data history, and see what apps have been using the most data and start from there
For data trackers, my data manger will be the best option for you. It can track even the 90 day plans
07-30-2017 09:16 PM
@jlucianoo wrote:Hi everyone,
Thanks,
Jeff
Hi Jeff,
it is more likely that there is an issue with your phone and there is a lot of data leaking. If you have an iPhone I suggest you download an app that tracks data. Just search for it in App Store, there are a bunch for free. You will then be able to see. Also you can look in the phones settings and it will show you what apps are using data and how much they have been using. I suspect you have a rogue app.
