08-02-2026 12:43 AM
My data usage is showing 45 gb in the app since July 29 while if I check the usage individually for each day it is coming around 12gb. Do I need to raise a ticket and if yes how do I raise it.
08-02-2026 10:32 AM
The data tracker is usually accurate, but if you believe that there is an error, you can submit at ticket for CSA to double check,
Please use this link to the Public Mobile Chat Bot which will direct you to creating a trackable ticket.
08-02-2026 01:07 AM
Thank you for the response. In usage overview it shows 45 gb while in usage breakdown for each individual day, if I sum up it is not even 10 gb.
08-02-2026 01:03 AM
for accurate usage info; log in to your Public Mobile account...the see Usage Breakdown. You'll see you current data allotment and how much you've used.
