Data usage incorrect
Giuseppe1
My history only shows a small amount of data usage, but the summary screen tells me that I have no data left.
Why?
@Giuseppe1  - go by what is showing left on your Self Serve account, as that is the most accurate amount remaining.
The data usage details are normally a bit delays about 6-12 hours. So what you used today should all be detailed tomorrow.
Timer
@jwaal
phone device or tablet, not working at well but from computer is good,
they upgrade new design website but not yet the system complete updated maybe soon,
jwaal
OK, take two. My history on the Android app shows I haven't used any since my month started. When I check using my computer, all is ok. So wonky Android app?
I guess I should have simply edited my first reply.
Timer
@Giuseppe1
use browser from computer, clear cache and cookies and use one page inPrivate mode,
to  Login Page
or call *611 to check it out your data usage.
jwaal
Are you verifying your account using your phone? When I verify my usage with my Android phone or tablet, it says I have used up all of my calling time even though the history shows I haven't used any since
Why?
If the amount is about 5MB, this is just something that Public Mobile's systems do.  It add-ons this small usage amount and then later removes it later to compensate.
