Data usage doesn't add up
09-26-2024
08:09 AM
09-26-2024
04:13 PM
computergeek541
Month just rolled over 3 days ago. Daily data usage for the 3 days totals about 38 mb. PM shows that I've used 132 of my 250 already for the month. This has been going on for awhile.
My Account
09-26-2024 11:25 AM
Under the current Public system, as long as your phone is online, the usage overview will always show 100MB more data used than actual usage.
09-26-2024 09:27 AM
HI @mtlexposfan
it looks like a "buffer" usage only. There is always that minor data usage, but it used to be within 5Mb but lately it jumps to 100Mb. From what we know, the 100Mb is just a "ghost" image, it will disappear and would not affect you. But if you are really blocked from user mobile data after 150Mb because the 100Mb "buffer" usage is there, ask PM support agent to check
please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
09-26-2024 09:23 AM
They are both PM numbers. Ever since the new plan rolled out the 250 is used in about a week and when you add up the daily usage it's a fraction of this. Everything is turned off except for maps.
09-26-2024 08:18 AM
I've had the same problem ever since this plan was switched to a new system. Nothing else has changed for me but my data seems to disappear quicker.
09-26-2024 08:11 AM
The Public Mobile adds up data vs how your smartphone will always vary. You will have to go with what Public Mobile says.
